chrystal
Message 1 of 5
slow BB
For the last 4 days our BB has been very slow. Done a test and comes in at 480kbps when it has been 5meg. I havnt disconnected the Hb, but did reset it 3 dys ago.
ADSL line status
Connection information<script type="text/javascript"></script>
Line stateConnected
Connection time2 days, 1:55:12
Downstream6,528 Kbps
Upstream448 Kbps
ADSL settings<script type="text/javascript"></script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)12.8 dB / 19.0 dB
Line attenuation (Down/Up)27.0 dB / 15.5 dB
Output power (Down/Up)19.8 dBm / 12.3 dBm
Loss of Framing (Local)20
Loss of Signal (Local)14
Loss of Power (Local)0
FEC Errors (Down/Up)18803 / 14
CRC Errors (Down/Up)97 / 2147480000
HEC Errors (Down/Up)nil / 7
Error Seconds (Local)172
What does this show. Thanks
4 REPLIES 4
raymie67
Expert
Message 2 of 5
Re: slow BB
you need to run the BT speedtester and post those ressults, especially the IP profile value
If my post was helpful then please click on the Ratings star on the left-hand side If the the reply answers your question fully then please select ’Mark as Accepted Solution’
chrystal
Message 3 of 5
Re: slow BB
The result of the test
FAQ
Results Image not loaded
<script type="text/javascript"></script> Test1 comprises of Best Effort Test: -provides background information.
 Download  Speed
 450 Kbps
0 Kbps500 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 450 Kbps
 For your connection, the acceptable range of speeds is 50-500 Kbps.
 Additional Information:
 Your DSL Connection Rate :6528 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 500 Kbps
Message 4 of 5
Re: slow BB
your profile is low at 500 just stay connected for about another day and it should return to normal automatically
chrystal
Message 5 of 5
Re: slow BB
Thanks for your help
