lukeool
Message 1 of 34
slow adsl conection and no fibre services in sight
i have a pretty slow adsl conection and it dosent look like i will be getting any fibre services in a long while. i recently purchased a new freeview box and it has bbc iplayer o it but when i want to watch somthing it playys for 2 seconds and starts buthering over and over again. there is no cable broadban in place so i cant w=switch to virgin or event get there tv service. how can i speed up my connection and when will i get fibre optic as every time i check it says i will be getting fttp but i dont know when.
33 REPLIES 33
jac_95
Guru
Guru
Message 2 of 34
Re: slow adsl conection and no fibre services in sight
Hi, to help us find the problem with your connection please may you see the following steps below:
1) Are you connected by master or test socket?.
2) Can you please run a BT speed test http://speedtester.bt.com (not beta version)
3) is there any noise on your line. dial 17070 option2 from landline. should be silent but slight hum normal on cordless phone.
4) please post adsl line statistics
ADSL Line Stats Help
If you have a BT Home Hub then....
Then:
1) Go to http://192.168.1.254 or http://bthomehub.home
2) click Settings
3) Click Advanced Settings
4) Click Broadband
5) Click Connection or sometimes called ADSL
The direct Address is http://bthomehub.home/index.cgi?active_page=9116 (for bthomehub3)
Cheers,
James
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
lukeool
Message 3 of 34
john46
Message 4 of 34
Keith_Beddoe
Message 5 of 34
Connection speed should be about 7200Kbs, so there is some bandwidth being lost somewhere, as there is only 8.9dB margin available.
john46
Message 6 of 34
could you try and connect your hub to the test socket and then post back the hub stats  also  could you click on  show more detail;  and post the extra stats as well please testsocket2.jpg
lukeool
Message 7 of 34
john46
Message 8 of 34
have you tried connecting to the test socket ?
lukeool
Message 9 of 34
No and I can't anyway it's in the hallway
jac_95
Guru
Guru
Message 10 of 34
Hi,
if your able to try the test socket (found behind the removable bottom faceplate of the master socket) then this will eliminate any internal wiring problem.
From your adsl stats there seems to be a problem as your lossing your bandwidth somewhere, unless you can try the test socket then we can't rule out a problem with your internal wiring.
If your able to try the test socket, can you repost your adsl line stats with a bt speedtester with the router in the test socket.
Someone will always be around to help you.
cheers,
James
Try a Search
