robbieburch
Message 1 of 4
slow broadband down loads
Just returned from holidays (everything was left switched on while away) but speed is terrible, at 0.34 Mb download. Checked and found that I was only connected for about 5 hours. Do I just wait and hope? I found the following information although I have no idea what it means:
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 05:38:17
Downstream511 Kbps
Upstream1,031 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.5 Annex A
Latency typeFast
Noise margin (Down/Up)28.9 dB / 6.1 dB
Line attenuation (Down/Up)52.4 dB / 30.0 dB
Output power (Down/Up)3.4 dBm / 1.5 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)2272 / 0
HEC Errors (Down/Up)3312 / 0
Error Seconds (Local/Remote)247 / 0
3 REPLIES 3
Message 2 of 4
Re: slow broadband down loads
You should be able to recover the speed by simply disconnecting the ADSL input for about 20 seconds, then reconnecting it.
What has happened is that something has caused the home hub to resync at a lower speed, probably just some interference or a working party interruption.
robbieburch
Message 3 of 4
Keith
Brilliant. Problem solved. Many thanks.
Message 4 of 4
Excellent Smiley Happy
Sometimes it just need an opportunity to re-synch. Its not usually necessary to restart the home hub, a simple disconnection of the line is quicker and less disruptive.
