imjolly
Message 21 of 28
Re: slow broadband, drop outs all the time - need help please
no don't switch off
if there has been no drops in connection then that is what you want and the last 2 lines of stats will be the same as previousely posted  that will show connection stable
Robertgee
Message 22 of 28
Just had a look through my event log and line stats and it shows that the connection has been going for just shy of 4 days. I wasn't at my house over Xmas so it must have reset/switched off due to power cut or something. The line stats are identical so will repost the ones from before if that's ok.
imjolly
Message 23 of 28
no please post the last set of 2 lines in the logs - the intention is to show when the last reset was and connection has been fine since
Robertgee
Message 24 of 28
Cool. Will do that in a bit for you.
Robertgee
Message 25 of 28
As required. This is the last point of cut off (not done by me) and the info to show stable connection for 3 days +
Thanks for helping. please elt me know what you can do.
Rob
imjolly
Message 26 of 28
your noise margin is very high and as you now have the 3+ days connection time see if mods will reset back to 6db
mods will post a contact us link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
PaddyB
Moderator
Moderator
Message 27 of 28
Hi Robertgee,
I'll be able to take a look at your connection. Please send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Robertgee
Message 28 of 28
PaddyB
Have done as requested. Thanks very much in anticipation of your help.
Rob
