Message 1 of 9
slow broadband fast lan
hello all!!!
It's been so many days now that I am struggling to initiate my wireless broadband connection. The hub 3 is new all the cables are fine the pc is fine but still after numerous calls to BT i have a wireless speed up to 1.3 Mb and LAN speed 17.0 Mb.
The technician came and the problem was not resolved. My pc is 2 years old and they' ve suggested for me to buy an external adaptor....My broadband was working fine until a week ago using another hub 3 when **bleep** broke loose..
I don't believe its a lap top issue even though they would very much like for me to believe so.....
What I am suppose to do now....stay for ever grounded in cable?
please someone help!!!!!!!
8 REPLIES 8
Message 2 of 9
Re: slow broadband fast lan
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 12:55:17
Downstream:19.59 Mbps
Upstream:1.117 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):5.6 dB / 6.8 dB
Line attenuation (Down/Up):15.3 dB / 7.4 dB
Output power (Down/Up):19.9 dBm / 11.0 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):609 / 72
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):2369 / 36
Error Seconds (Local/Remote):540 / 24
Message 3 of 9
have you tried changing wireless channels and going from b/g/n to b/g that may help
Message 4 of 9
how do i do that? I know how to chnge channel but where is the b/g thing I don't see it!!!
Currently I am in channel 11
Message 5 of 9
ok found it but still speed is slow.....even with b/g alone......
Message 6 of 9
you can try downloading inssider2 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own. If you then enter your router and change your wireless channel to a free or less congested channel.
to manually select a free or less congested channel you will need to turn of the automatic selection in the HH3
Message 7 of 9
i tried that as well...I am the only one around using channel 11 but still no success ....Smiley Sad
Message 8 of 9
have you tried downloading the most up to date drivers for your wireless adaptor
Message 9 of 9
yes we' ve run all these tests over the phone today they are up to date.....
