NeilGuy
Message 1 of 20
slow broadband upload speed
My postcode is NN11 0XR.  Using BT HUB 4a with wifi. Max download speed about 7-8 mbps. Upload speed about 0.3mbps. It used to be about 0.7mbps but it has gone down now even further - I do not know why. Most of my work depends on decent upload speeds. This is now so slow, uploading data and particularly pdf files to a web site which I do regularly is almost impossible - it keeps timing out. BT  Infinity is not available in this area. Can you help please.
19 REPLIES 19
imjolly
Message 2 of 20
Re: slow broadband upload speed
post stats from hub  as hh4  need to gp to logs then wan and you are looking for 2 line together when router last reset showing connection speed and noise margin
run btspeedtester and when first test completes then run diagnostic test and post results  must be with ethernet connection and not firefox  best with edge  http://www.speedtest.btwholesale.com/
NeilGuy
Message 3 of 20
 Not sure how get Home HUB 4 data. I will reply again later
NeilGuy
Message 4 of 20
imjolly
Message 5 of 20
can you use the btspeedtester link I posted and post diagnostic results using ethernet
NeilGuy
Message 6 of 20
BT Home Hub 4A Event log . Having a problem with the BTspeedtest.
imjolly
Message 7 of 20
need to change category to wan and you are looking for last time router reset  if you check hub stats you will see conenction time which will give you some idea where to look in wan logs
did you try edge for btspeedtester
NeilGuy
Message 8 of 20
I don't have an Ethernet connection. Using Edge, but I have a problem getting into the BT ID due to passcode issues.
NeilGuy
Message 9 of 20
HERE ARE THE WAN STATS
imjolly
Message 10 of 20
not sure why you need BTID  btspeedtester just needs your phone number  no need for test 3
unfortunately you need to run with ethernet connection as wireless is susceptible to interference from with your home and from outside
