Newbie
Message 1 of 21
slow broadband
Hi use to get around 7mb broadband speed up until the last 4 weeks where it has reduced to around 2mb and constantly buffering with the likes of youtube etc. My son had this problem a couple years ago and one of the mods who was very helpful reset the ip profile i think and it fixed the issue is there anyway i can contact the mods directly to see if this can done to see if it resolves my problem? Thanks in advance.
20 REPLIES 20
Message 2 of 21
Re: slow broadband
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Newbie
Message 3 of 21
Re: slow broadband
I cant find those stats in any of the logs im using the home hub4
Message 4 of 21
Re: slow broadband
they are there from the last time your hub restarted
Newbie
Message 5 of 21
Re: slow broadband
ive just done a speed test as well if this helps.
FAQ
Results Image not loaded
1. Best Effort Test:
Download Speed : 1.95 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information
Message 6 of 21
Re: slow broadband
that is a good start but those two lines are needed please
Newbie
Message 7 of 21
Re: slow broadband
ok managed to locate the stats it was under the wan tab.
11:33:25, 09 Sep.( 71.720000) DSL noise margin: 25.00 dB upstream, 14.60 dB downstream
11:33:24, 09 Sep.
( 71.650000) DSL line rate: 448 Kbps upstream, 8128 Kbps downstream
Ive also changed the filters.
Message 8 of 21
Re: slow broadband
ok thanks you now need to repost those two lines in 3 days time and if your speed has not improved we can ask the forum mods to assist you in getting your profile reset
Newbie
Message 9 of 21
Re: slow broadband
ok John thanks but this has been going on for the last 4 weeks are u saying nothing can be done for three days until i post more stats?? Just would like to get this reolve as soon as possible as my son is having problems playing his xbox and we cant stream video smoothly.
Message 10 of 21
Re: slow broadband
the mods cannot arrange a reset until you can show 3days + stable connection because unless you can show this there is no point in resetting as the profile will just drop again
