Message 1 of 8
slow conection
Hi just wondered if there was any magic answer to my really slow conection.
its never been lightning fast as we are rural but in the last few days it has gone from around 6 mbps to 2 mbps
coincidently there is a lot of work going on locally as they are laying on fibre , i wondered if all the messing about up poles has had an effect on my old conection,
now off to try filter and spare router see what that does,
Joe
7 REPLIES 7
Message 2 of 8
Re: slow conection
Can you post your hub stats
enter your phone number and post results remember delete number  https://www.btwholesale.com/includes/adsl/main.html
try quiet line test. Dial 17070 option 2 should be quiet and best with corded phone
Message 3 of 8
Re: slow conection
hiya , thanks for the responce  its actually a lot better today oddly
all quiet on the line test maybe ill try that when its bad again ,
Message 4 of 8
Re: slow conection
Which hub do you have?
Message 5 of 8
Re: slow conection
my bt one died in a storm a few years back so im using a Netgear  N600
Message 6 of 8
Re: slow conection
You need to find the stats showing connection speed, internet connection time, noise margin, attenuation, max attainable speed
Message 7 of 8
Re: slow conection
thankyou for that ok ill hunt about .. may not worry for a bit as its been fine for a few days now , i do wonder if its all the work going on locally with them installing fiber ..
Message 8 of 8
Re: slow conection
The fibre installation should not affect your adsl connection
