mungy
Message 1 of 25
slow internet for the last few days
As the title says, I have been experiencing very slow internet for the last few days.
 Download speedachieved during the test was - 749 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :7424 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 6500 Kbps
Normally I get close to 7000kbps.
I'm pretty sure our exchange is Waunfawr
24 REPLIES 24
mungy
Message 2 of 25
Re: slow internet for the last few days
results from ADSL line status:
Line stateConnected
Connection time13 days, 22:41:50
Downstream7,424 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)8.9 dB / 21.0 dB
Line attenuation (Down/Up)39.0 dB / 21.5 dB
Output power (Down/Up)19.8 dBm / 12.1 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)65863480 / 29
CRC Errors (Down/Up)1498 / 2147480000
HEC Errors (Down/Up)nil / 15
Error Seconds (Local)1032
Geoff93
Recognised Expert
Message 3 of 25
Have you checked your exchange for problems
http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
If you are not sure it is Waunfawr then put your phone number in here and it will confirm it.
samknows.com/broadband/exchange_search
mungy
Message 4 of 25
Thanks for the links.
Yes, it is Waunfawr. No reported faults
Message 5 of 25
Hi
There your connection is fine it is a throughput issue I suggest you mail the board mods with your account no phone number and a link to this thread and ask them if they can get your throughput increased
Trev666
Message 6 of 25
test.....
FAQ
Results Image not loaded
<script type="text/javascript">// paintProgressAndMessageOnBar(-1 ,"Last Test Required" ); // </script> Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
48 Kbps
0 Kbps250 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 48 Kbps
 For your connection, the acceptable range of speedsis 100-250 Kbps.
 Your DSL Connection Rate :192 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 135 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 8.01:33.33:58.73 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
Upload Speed
367 Kbps
0 Kbps448 Kbps
>Upload speed achieved during the test was - 367 Kbps
 Upstream Rate IP profile on your line is - 448 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit FAQ section if you are unable To understand the test results.
.... any ideas guys ?    nice links btw Geoff.
Geoff93
Recognised Expert
Message 7 of 25
Thanks Trev
Can you post the full stats from your router
For homehub – type 192.168.1.254 into your browser
Navigate to ADSL Settings or use the A-Z at the top right of the home page and scroll down to ADSL Settings and click on it
Click on More Details and then post the results.
then someone may be able to help and offer more advice.
Message 8 of 25
could you please post your full hub stats as your problem is very different to the original post on this thread type 192.168.1.254 in your browser search bar then once past the password stage navigate to adsl then copy and paste the page back here
Trev666
Message 9 of 25
    Cant find it using ip address what was bt .....link for it ? sorry not with it today 😛
Geoff93
Recognised Expert
Message 10 of 25
