Trev666
Message 11 of 25
Re: slow internet for the last few days
   Webpage not found  ... been looking ..bthomhub etc etc cant find it wont need it soon gonna throw pc and tv in a skip.......lol
Message 12 of 25
try this way 192.168.1.254
mungy
Message 13 of 25
I emailed the mods. anyone any idea on response times?
Message 14 of 25
Anything up to 72 hours maybe sooner all emails are answered in turn but they are only a small team and mainly work Monday to Friday one or two are about over the weekends just a matter of waiting
mungy
Message 15 of 25
thank you, john46
Trev666
Message 16 of 25
ADSL line status
Connection Information
Line stateConnected <script type="text/javascript"></script>
Connection time0 days, 00:19:43
Downstream3,936 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)9.3 dB / 21.0 dB
Line attenuation (Down/Up)48.9 dB / 30.5 dB
Output power (Down/Up)6.0 dBm / 1.7 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)20 / 1
CRC Errors (Down/Up)11 / 0
HEC Errors (Down/Up)48 / 0
Error Seconds (Local/Remote)7 / 1
     Sorry for delay i got fed up and drowned my sorrows..........    oh i had to reset hub as i lost password
Thanks in advance for any help.
reme8488
Message 17 of 25
Hi Trev, it looks like you've had a low sync event or two which has caused a low IP profile.  Your sync speed is better now and hopefully if the line is stable for the next 3 - 5 days you should see your profile increase to where it should be.
Worth running another BT Speedtest though if you feel brave enough.  Don't reboot the hub is at all possible for as it will work against you having your profile increased.
Kind regards... Tom
BT Infinity2:
Trev666
Message 18 of 25
 Thank you Reme i will wait for a few days and see Smiley Sad
reme8488
Message 19 of 25
Trev, if, after 5 days you don't see an increase in your IP profile and have had no resyncs (downwards) I would contact one of the forum mods and ask them to look into things for you.
Otherwise, best of luck Trev and I hope you get your speed increase in due course.Smiley Happy
Kind regards... Tom
BT Infinity2:
mungy
Message 20 of 25
Still got slow speed here, about 300kbps.
During the early hours of the morning the last 2 days it was up to 7000kbps. during the day it has been around the 300kbps mark.
I have sent a couple of emails to the mods but as yet no replies.
Can a mod please do something about this. My internet is almost useless.
