spdruce
Message 1 of 4
slow speed and ip profile
Hello again & again & again. So, in March I posted the latest in a long, long line of queries about my constantly inconstant ip profile which was succesfully solved by the mods.... so - here we go again. since my post in March and my ip profile re-setting I appear to have had fairly regular re-sets. I have attached a list of some of the more recent stats. My current ip profile is now  1.75 and I am in the process of tearing my hair out. is there no end to this?
Is there nothing that can be done to make my line more consistent or is this the price I pay for living in a rural location?
07:56:59, 07 Jun.
(331557.270000) DSL noise margin: 20.00 dB upstream, 9.00 dB downstream
07:56:59, 07 Jun.
(331557.200000) DSL line rate: 448 Kbps upstream, 2240 Kbps downstream
Best Effort Test: -provides background information.
Download  Speed
1.71 Mbps
0 Mbps
2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.71 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :2.24 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 1.75 Mbps
11:52:04, 03 Jun.
( 86.040000) DSL noise margin: 20.00 dB upstream, 6.00 dB downstream
11:52:03, 03 Jun.
( 85.970000) DSL line rate: 448 Kbps upstream, 3296 Kbps downstream
05:57:51, 25 May.
(298382.610000) DSL noise margin: 19.00 dB upstream, 6.60 dB downstream
05:57:51, 25 May.
(298382.540000) DSL line rate: 448 Kbps upstream, 2656 Kbps downstream
19:05:55, 21 May.
( 90.410000) DSL noise margin: 20.00 dB upstream, 6.10 dB downstream
19:05:55, 21 May.
( 90.340000) DSL line rate: 448 Kbps upstream, 2720 Kbps downstream
03:30:36, 17 May.
(812547.180000) DSL noise margin: 20.00 dB upstream, 6.20 dB downstream
03:30:36, 17 May.
(812547.100000) DSL line rate: 448 Kbps upstream, 2176 Kbps downstream
10:06:19, 11 May.
(317898.100000) DSL noise margin: 21.00 dB upstream, 6.10 dB downstream
10:06:19, 11 May.
(317898.030000) DSL line rate: 448 Kbps upstream, 2912 Kbps downstream
3 REPLIES 3
imjolly
Message 2 of 4
Re: slow speed and ip profile
the problem is your hub is dropping connection probably due to noise on the line and the longer your line the more chance of noise causing a problem
it is not actually the profile that is reset it is probably the noise margin reset back to normal which then gives a faster connection speed which in turn gives a higher profile - profile is based on conenction speed not the other way round
try quiet line test and see if you can hear any noise  best with corded phone
spdruce
Message 3 of 4
Will do test as soon as I can, this is something I have had a problem with in the past however the last broadband engineer I had out reckoned he had put a filter on the line which would help with line noise from neighbouring farmers electric fence. Will report back as soon as.
spdruce
Message 4 of 4
Quiet line test good no discerneble noise. latest stats attached
  1. Best Effort Test: -provides background information.
Download  Speed
1.71 Mbps
0 Mbps
2 Mbps
 Your DSL Connection Rate :2.72 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
09:12:43, 18 Jun.
(74982.870000) DSL noise margin: 20.00 dB upstream, 9.20 dB downstream
09:12:43, 18 Jun.
(74982.790000) DSL line rate: 448 Kbps upstream, 2720 Kbps downstream
12:24:03, 17 Jun.
( 83.510000) DSL noise margin: 21.00 dB upstream, 9.30 dB downstream
12:24:03, 17 Jun.
( 83.440000) DSL line rate: 448 Kbps upstream, 2464 Kbps downstream
