gcdcfc
Message 1 of 8
slow speeds (again)
On the infinity 2 package; would usually get around the 75mb advertised but recently i'm lucky to get 40.
Tried using the online chat assistance and they disconnect everytime, shocking poor and not acceptable. Then they tell me to ring up the infinity helpline and then disconnect again!
Great customer service you guys have going there.
Anyway wheres the 35mb gone too? Should be getting 20mb upload speed, I get roughly 8...
Stop prancing around advertising Bt Sport and actually bother to deal with customers.
Tags (3)
7 REPLIES 7
john46
Message 2 of 8
Re: slow speeds (again)
Hi
The reason your speed has dropped is because of a noise issue this has caused the DLM to reduce your IP profile to stabilise the line all you need to do is leave the connection alone for up to 2 weeks and once the DLM sees the line as stable again it should start to rise again
gcdcfc
Message 3 of 8
What do you mean by a noise issue?
Deathtrap3000
Recognised Expert
Message 4 of 8
Run the bt wholesale speedtester and get your ip profile to see what package you are on.
gcdcfc
Message 5 of 8
It's  rubbish.
down: 71.44 <- first time in weeks its been this high
up:11.98 <- was getting 20 previously
ping: 352.75 <--- no idea if this is good or not..
I've been trying since day one to do speed tests on the wholesale page.
Every single time I have tried to run the diagnostic test I get this message
"No Fibre to the Premises (FTTP) services have been found at this address. Please check the postcode or use the Telephone Number or Service ID to conduct the test.
Click here to try again"
gg30340
Message 6 of 8
If you have Infinity it is FTTC Fibre to the Cabinet, not FTTP Fibre to the Premises. You need to run the diagnostic and put in your phone number.
gcdcfc
Message 7 of 8
"The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider."
Surprise surprise
gg30340
Message 8 of 8
Carry out a factory reset of the Homehub by pressing a pin into the recess button on the rear for about 20 seconds. Once it has all reset and restarted try and do the test again. Do the full test including the diagnostic test and post the results back here.
Do not reset the white Openreach Modem.
