splitpin300
Message 11 of 34
Re: slow upload speed 0.004 mb/s
Is this the information required?
ADSL Line Status
Connection information
Line state:Connected
Connection time:0 day, 00:08:06
Downstream:7,008 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):6.8 dB / 23.0 dB
Line attenuation (Down/Up):32.0 dB / 17.5 dB
Output power (Down/Up):19.9 dBm / 12.3 dBm
FEC Events (Down/Up):480 / 3
CRC Events (Down/Up):0 / 0
Message 12 of 34
yes but can you 'show detail ' at bottom and post rest of errors
splitpin300
Message 13 of 34
This shows a bit more, its only been restarted a few mins
ADSL Line Status
Connection time:0 day, 00:13:10
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.3 dB / 23.0 dB
FEC Events (Down/Up):905 / 3
CRC Events (Down/Up):1 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):7 / 0
Error Seconds (Local/Remote):0 / 0
Message 14 of 34
due to short conenction time there is virtually no errors to speak off so need to repost later today
can you run btspeedtester again please
are you conencted to test socket?
did you try quiet line test?  was it quiet?
splitpin300
Message 15 of 34
now back in the test socket
updated list
ADSL Line Status
Connection time:0 day, 00:00:57
Downstream:7,776 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):5.4 dB / 24.0 dB
Line attenuation (Down/Up):30.5 dB / 17.0 dB
Output power (Down/Up):19.9 dBm / 11.9 dBm
FEC Events (Down/Up):1302 / 0
CRC Events (Down/Up):7 / 0
HEC Errors (Down/Up):231 / 0
0 / 0
Speed test
down 6.25
up 0.06
ping 253.88
Quiet test was silent
Message 16 of 34
so in test socket the conenction speed has improved, noise margin about same, attenuation dropped 1.5db but upload speed still low and high ping
is there anything here that helps
http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
splitpin300
Message 17 of 34
the router has been moved to the other end of the house in the last weeks and the speeds are still the same.
everything else is turned off, download is fine its just upload that can get even tiny pictures to ebay, photobucket or sent via email.
Im at the end of the line now so to speak.
splitpin300
Message 18 of 34
I know its a long shot but things got a lot worse when the villae shop over the road had a lottery machine installed with its own phone line which comes off the same pole as my house.
splitpin300
Message 19 of 34
Here are the latest results
ADSL Line Status
Connection time:0 day, 02:38:06
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.1 dB / 24.0 dB
Output power (Down/Up):20.3 dBm / 12.4 dBm
FEC Events (Down/Up):74066 / 0
CRC Events (Down/Up):35 / 0
HEC Errors (Down/Up):475 / 0
Please can anyone help? would a change of provider solve the problem?
Message 20 of 34
your stats look ok can you run btspeedtester please
changing ISP would only help if you went to cable and may help if you went to an LLU provider
