Newbie
Message 11 of 20
Re: slowed down speed bt broadband
wireless also same with wired this started happening a few days ago  getiing 300kb at most compared to the usual 2 to 4mb
Message 12 of 20
when you had faceplate off did you notice if the bellwire was disconnected from terminal 3 in all sockets as this is a known source of noise on your line.
from your stats your crc/hec errors are vey high for such a short time connected and these will certainly hamper your download speed
Newbie
Message 13 of 20
all wires were connected and terminal 3 was in the right place
Message 14 of 20
then you should disconenct the bellwire on terminal 3 as that is no longer required on modern phones and can cause noise on your line  see here
bellwire removal
Newbie
Message 15 of 20
so just take out the wire connected to 3? ok il try that now thanks
Newbie
Message 16 of 20
broadband still super slow
Message 17 of 20
if you have removed bellwire form all your sockets then can you post new router stats please to see if stats have improved
Newbie
Message 18 of 20
thanks for helping me imjolly i just phoned up the bt help line and appartently my area is effect by noise on line and bad weather according to the message i got but still thanks for your help
Message 19 of 20
ok then just post back if it continues and we will try and help you further
Message 20 of 20
anything shown here for your exchnage http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
