Message 1 of 13
slower Broadband after moving home .
Hello , so i recently moved about 12 days ago , i used to have 16mbps in my old place now im having only 5mbps . I heard that i need to stay connected for about 10 days in order to getfull speed .
I am connected 12 days now and nothing is changed . I am providing some more details below .
Line state:Connected
Connection time:12 days, 10:47:17
Downstream:5.188 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):3.4 dB / 25.0 dB
Line attenuation (Down/Up):44.3 dB / 28.0 dB
Output power (Down/Up):20.0 dBm / 12.0 dBm
FEC Events (Down/Up):0 / 24
CRC Events (Down/Up):28346 / 111
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):31353 / 2
Error Seconds (Local/Remote):14687 / 186
What should i do in my case ?
Thank You .
12 REPLIES 12
Message 2 of 13
Re: slower Broadband after moving home .
You could try connecting to the test socket other than that you are getting near to the speed your line can support now
Message 3 of 13
can you check your exchnage and see if 21CN enabled
check exchange
Message 4 of 13
just checked your previous post presumably from previous address and then you were about 2km from exchange whereas now you are 3.2km - significant change
Message 5 of 13
so is that maximum i can get right now ?
Message 6 of 13
is your exchnage 21CN enabled?
Message 7 of 13
this link will give an idea of expected speed on good line with no noise problems  http://www.kitz.co.uk/adsl/max_speed_calc.php
Message 8 of 13
21CN WBC status:
Enabled
Message 9 of 13
are you connected to test socket as that may increase your current speed.  as you have just moved into a new home it appears that wholesale have put you on adslmax whereas before you were on adsl2/2+.  if you use the link I posted you will get an idea of likely speed if mods manage the upgrade
I have asked the mods if they can see if you can get back to adsl2/2+ which will give a bit more speed.  the  mods will post a contact us link.  it may be that wholesale will not give an option of adsl2/2+ which has happened a few time recently but need to wait and see
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
Moderator
Moderator
Message 10 of 13
Hi souloo,
Thanks for posting. I'll take a look into this for you. Drop me an email with the details. You'll find the "contact us" form in the about me section of my profile.
Cheers
David
