Message 1 of 30
slowing speed
2016-04-01 (2).pnghello i came to bt from sky on the 16th of feb this year, the first two weeks i was getting 32 mbps download and 6 upload well now it has dropped to only 20 download but stayed at 6 upload which seem quite a big drop my stats are2016-04-01 (2).pngwith sky i was getting about 25 download and also i am having to reset the router every other day or more because of disconnections can anyone help
29 REPLIES 29
Message 2 of 30
Re: slowing speed
the manual resets and also drops in connection have resulted in the DLM increasing your noise margin to 16db normal 6db and this has caused your conenction speed to drop.  looks like a banded profile
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
are you using master or test socket or do you have an SSFP?
were you on sky fibre
Message 3 of 30
Re: slowing speed
Thanks for reply yes aim using master socket and its the mk2 faceplate and yes I was on sky fibre
Message 4 of 30
Re: slowing speed
Tried the line that's quiet so do I have to phone customer services
Message 5 of 30
Re: slowing speed
I would try the test socket with a filter before you try for an engineer to eliminate your internal wiring as being the problem in case you get charged £129.99 for the visit
test socket shown by black arrow
Message 6 of 30
Re: slowing speed
2016-04-02.pngthis is from today using master socket and new filter so could it be a fault on the line
Message 7 of 30
Re: slowing speed
Have you rebooted the router or move it location just now? A connection time of 4 minutes either means you have, or the connection has dropped.
Message 8 of 30
Re: slowing speed
No it was with me connecting to test socket
Message 9 of 30
Re: slowing speed
Ok so basically you now need to leave it in the test socket. Ignore the speed for now, what you need to focus on is the stability, if the connection is still dropping when on a banded circuit and in the test socket then you need an engineer visit.
If the line remains stable in the test socket, then banding will be released and the speed will increase. If it remains stable in the test socket it also indicates your internal wiring was the cause of the problems.
Message 10 of 30
Re: slowing speed
thanks you have been so helpful after everything as settled down i might purchase a new router
