avifec
Message 1 of 3
smart hub 6 keeps reseting itself
Recently changed from a hub 3 to a smart hub 6 and it keeps dropping out from the internet and has to be reset. I have just noticed that it seems to coincide with a incomming phone call, any ideas.
2 REPLIES 2
imjolly
Message 2 of 3
Re: smart hub 6 keeps reseting itself
if dropping when phone rings then check all sockets have filter  replace the filter where phone connected
if you have filtered master socket then connect to test socket with a new filter and then phone home and see if conenction still drops  if it does then check you have no dial tone at any extension socket  if that is ok then sounds like high resistance fault and need to report phone fault to 151
avifec
Message 3 of 3
Thanks imjolly I did suspect a filter myself but I wanted some confirmation before I went out and bought one. I have now changed it and tried a couple of test calls and so far so good.
avifec
