rebeccarooney45
Message 1 of 18
some devices able to connect to the wireless and some not able to
So I recently decided to reset my lenovo laptop to factory settings using the lenovo one key recovery. Unlike before, I now cannot connect to my bt infinity wireless or wired internet. It say limited connection but won't allow internet access.
I then realised that several devices are connected and working with the home internet including computers, ipods etc (all of which have been connected before I reset my laptop). But any new devices (including my ps3 and ipad) will not connect and have the same problem as the laptop.
please someone help!
17 REPLIES 17
Words
Message 2 of 18
Re: some devices able to connect to the wireless and some not able to
It's almost certainly something in the wireless adapter settings. Try setting the hub to no password/security and see if they then connect. Then put the security back on (WPA2) and try to reconnect them. You will probably be asked for the key at that point and with a fair wind everything will work.
rebeccarooney45
Message 3 of 18
thanks for the quick reply but have tried that already and no luck
john46
Message 4 of 18
have you checked the wireless card and ethernet card drivers are installed and up to date
rebeccarooney45
Message 5 of 18
yep everythings up to date
john46
Message 6 of 18
firewall settings ?
rebeccarooney45
Message 7 of 18
Someone had previously given me advice with regards to firewall settings so have tried to connect with firewall on and firewall off. But baring in mind it is not just my laptop, my ps3, ipad and any new devicesthat have never connected before fail to connect - for example when someone comes round to the house (unlike before) their phones, ipods etc wont connect
Bullitt
Distinguished Expert
Message 8 of 18
have you rebooted the homehub?
rebeccarooney45
Message 9 of 18
first thing I done was reboot it
DS
Distinguished Guru
Message 10 of 18
If you've never changed any settings on the hub, bar the admin password, I'd factory reset it - http://bt.custhelp.com/app/answers/detail/a_id/11386
Then see if those devices that couldn't connect now can.
-+-No longer a forum member-+-
