Message 1 of 5
speed and ip drop
can anyone tell me why my speed and ip profile should drop by 30 percent after power cut below are stats
Line state:
Connected
Connection time:
0 day, 20:35:16
Downstream:
544 Kbps
Upstream:
448 Kbps
ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.1 Annex A
Latency type:
Interleaved
Noise margin (Down/Up):
6.1 dB / 6.0 dB
Line attenuation (Down/Up):
63.5 dB / 31.5 dB
Output power (Down/Up):
14.3 dBm / 12.6 dBm
FEC Events (Down/Up):
158945 / 549
CRC Events (Down/Up):
33 / 56
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
HEC Errors (Down/Up):
47 / 42
Error Seconds (Local/Remote):
0 / 0
To reset back to the default BT Total Broadband username and password, click the 'Reset username' button.
 Reset username
Plese wait...
Applying...
WAN Status
Connection information
Line state:
Disconnected
Connection time:
Not available
4 REPLIES 4
Message 2 of 5
Re: speed and ip drop
your ip profile will reduce because of the reduction of your connection speed could you please also post the full results of the bt speed test
Message 3 of 5
Hi
435kbps down
448kbps up
Ip profile 479kbps
Before power cut
650 down
448 up
Ip 679
Seems strange y speed is dropping have had engineer out and no problems from my end
Richard
Message 4 of 5
hi just leave the connection alone for the next 3-5 days and let the line stabilise if you need any further help after that time please post back
Message 5 of 5
It only takes a maximum 72 hours now for the changes to be made to the IP profile. It used to be 5 days, but was reduced to 3 days about 12-18 months ago.
