Ook
Message 1 of 3
speed decreasing / unable to connect to broadband.
ok this is getting beyond daft , speeds all over the place from .26mb to 5.23mb , and days where ots all fine and period where it disconnects multiple times per hour ADSL line status Connection Information Line state Connected Connection time 2 days, 08:57:52 Downstream 4,224 Kbps Upstream 448 Kbps ADSL Settings VPI/VCI 0/38 Type PPPoA Modulation G.992.1 Annex A Latency type Interleaved Noise margin (Down/Up) 7.5 dB / 13.0 dB Line attenuation (Down/Up) 43.5 dB / 29.5 dB Output power (Down/Up) 6.8 dBm / 1.2 dBm Im just under 1km from my nearest exchange (as the crow flys) even though the downline attenuation says im more like 4km? from the exchange?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: speed decreasing / unable to connect to broadband.
Hi Ook,
Thanks for posting. Your stats aren't great to be fair. I can get it looked into. Drop me an email with your account details and a link to this post to forum.moderation.team@bt.com and we'll take it from there.
Cheers
David
Moderator
Moderator
Message 3 of 3
Hi Ook,
I've picked up your email and dropped you a reply.
Cheers
David
