Message 11 of 18
Re: speed differential
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 01:51:20
Downstream:4.438 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):15.0 dB / 25.0 dB
Line attenuation (Down/Up):41.1 dB / 22.0 dB
Output power (Down/Up):19.4 dBm / 12.4 dBm
FEC Events (Down/Up):39690 / 1
CRC Events (Down/Up):93 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):640 / 2
Error Seconds (Local/Remote):60847 / 4326
Message 12 of 18
well that has increased your speed to 4.4mb and if you get the noise margin reset to 6 that should bring speed up to what I suggested.  contact the mods
contact mods
can take up to 3 working days for mods to contact you
Message 13 of 18
 Download speedachieved during the test was - 2.75 Mbps For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps. Additional Information: Your DSL Connection Rate :4.54 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM) IP Profile for your line is - 3 Mbps
Message 14 of 18
your profile has not chnaged and is still based on your previous speed.  profile take 3/5 days connected 24/7 to catch up with your speed increase.  yo still need to contact mods and get noise margin reset to 6
Message 15 of 18
Ok have done that thanks will advise of the outcome in a week or so
Message 16 of 18
I have had my noise reset to 6 now and theses are the results from the BT speed checker:
Download speedachieved during the test was - 5.68 Mbps For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps. Additional Information: Your DSL Connection Rate :7.81 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM) IP Profile for your line is - 6.5 Mbps
Message 17 of 18
you are now at 7.8 mb with correct profile.  just let it settle now should be good
Message 18 of 18
looking good now just let it settle now
