jacksmack
Message 1 of 4
speed dropped by half
Over the last few days my speed has dropped from 7mbps to little more than 3,Any ideas guys??
I did the bt speed test and got an ip profile for the line of 3.5mbps
Download speedachieved during the test was - 3.26 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 3.5 Mbps
Line stateConnected
Connection time0 days, 1:04:38
Downstream8,128 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)13.1 dB / 27.0 dB
Line attenuation (Down/Up)24.0 dB / 16.0 dB
Output power (Down/Up)19.8 dBm / 12.0 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)42 / 0
CRC Errors (Down/Up)0 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)
0
3 REPLIES 3
john46
Message 2 of 4
Re: speed dropped by half
your IP profile has dropped due to some noise on the line causing some disconnections if you maintain a stable connection for 3/5 days with no restarts your IP Profile will rise automatically as will your download speed
jacksmack
Message 3 of 4
ok thanks for the quick reply,I will leave it and see
john46
Message 4 of 4
if after 3+ days it has not improved post back and we can help further
