staking
Message 1 of 2
speed has dropped 6mb !
from 20.8mb to 14.7mb
6mb drop in speed, what is going on.
co. down, northern ireland
also upload speed is now only 0.67mb  highest ive seen it at was 1.6mb
the internet was working perfect at 20mb, how can i get it back to this speed ?
1 REPLY 1
PC
Recognised Expert
Message 2 of 2
Re: speed has dropped 6mb !
Hi
If your on a wireless connection can you try connecting direct to your hub via an ethernet cable.
Then check to see if any change.
If you run the BT speed tester http://www.speedtester.bt.com/
This will give you your IP profile.
eg.-
Download speedachieved during the test was - 36616 Kbps
 For your connection, the acceptable range of speedsis 12000-38717 Kbps .
 Additional Information:
 IP Profile for your line is -38717 Kbps
Upload speed achieved during the test was - 1488 Kbps
 Upstream Rate IP profile on your line is - 2000 Kbp
You can check if your on a clear wireless channel using a free checker http://www.metageek.net/products/inssider/
The highest Upload I get is also 1.6Mb but this is due to my option 1 cap.
It would be interesting to see if your IP profile has dropped since installation.....
Sorry I have to go out.... perhaps if you can let us know your results someone may be able to decide what direction the problem is.
 Edit if your speed remains below 15Mb and your on Infinity ie you have option 1 or 2, then I believe that is  below the allowable threshold and BT have to fix the problem.... assuming it's not wireless problem..... Woops must rush.
Please Click On any Text in Blue as that automatically links to information.
PC (NDEGR)
