theragingpotato
Message 31 of 43
Re: speed is terrible!!!
Out of the blue, my speed has gone up to 7MB again. After booking an engineer for Thu BT support called me back about 30 mins later and said there was a problem at the exchange and my broadband would be fixed with no engineer visit. I asked why it had happened and what the problem was but they did not know or were unwilling to tell me.
However broadband now operating at expected speed and hopefully engineer won't make a visit on the and pull the plug out! Thanks to all for help/advice
geebuss
Message 32 of 43
how hard is it to up the capacity on a vp??
Tags (3)
Message 33 of 43
the time taken depends on how many vps the exchange has how many need upgrading it is software that is upgraded and requires specialist engineers to do the job they travel the uk doing this work so some times you may be lucky and its days other times it could be weeks depends on pressure of work
geebuss
Message 34 of 43
sigh still not resolved!!!
i'll be looking for a big discount when its fixed and maybe my mac code by the looks of it
geebuss
Message 35 of 43
my god still not resolved!!!
and wow dosnt take long for a post to get buried here know why??? cos there are soooo mnay complaints wtf is goin on with BT???
where was that guy from the press and journal ? i reckon theres a story here for the papers!!
title= BT fails its customers on so many levels
geebuss
Message 36 of 43
this website shows that all the tripe i've been told about how they will resolve the issue with the hot vp is rubbish there are no works planned!!!!!!!
http://usertools.plus.net/exchanges/?exchange=Keith&exact=3172&plugin=vp
geebuss
Message 37 of 43
bump and yes youve guessed it still not fixed
i find it amasing how fast this post is buried under the deluge of complaints about broadband speeds !!
wtf are BT playing at?
geebuss
Message 38 of 43
this is tonight !!!!! what is that number for ofcom????
FAQ
Results Image not loaded
This Test comprises of Best Effort Test: -provides background information.
Download  Speed
401 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 401 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :8096 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 7000 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit FAQ section if you are unable To understand the test results.
Community Manager
Community Manager
Message 39 of 43
Hi geebuss,
Could you send in your details so I can check what's already been done and send me a PM when it's done so I can pick it up?
Thanks,
Stephanie
Community ModeratorStephanie
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
geebuss
Message 40 of 43
email sent although i was already in communication with a member of your "team"
