Message 1 of 43
speed is terrible!!!
save me please from the speed woes i'm having
BT india is simply giving me the runaround !!!
this is a screenshot of the kind of speeds i'm getting and have been for around a month now with BT india admitting its a problem in the exchange but doing nothing!! or rather promising to fix and saying they will call in 2 days to confirm only for the next 2 days or 3 asking me!! if its fixed now i mean wtf?
heres the fault number if your willing to help
 VOL011-xxxxxxxxxxx
http://img513.imageshack.us/i/83268085.png/
42 REPLIES 42
Newbie
Message 2 of 43
Re: speed is terrible!!!
Join the club, unfortunately they're not going to tell you when it's being fixed, they'll simply hope a passing engineer has fixed it, then call you to check. This is from my own experience
Message 3 of 43
i wonder how far they can escalate the case ? 4 times they have promised a fix they say its now with the capasity team  i forget  the other teams they mentioned before that!!
i'm expecting another call tonight sigh but i've already ran a speedtest tonight so i know already its not fixed
maybe theres another team it'll be escalated to!
Message 4 of 43
Your best bet is wait a while for a mod to spot this but if they don't just PM a mod.
I feel your pain regarding India.
Message 5 of 43
BT India is truely awful.
Whenever I have phoned with a problem, no matter what it is, I get the same response... reset your router, or I'll run a line test!
After I refuse either doing either, they dont know what else to say, even when I have told them what to do to put it right, they do it wrong, at best, or just dont do anything!!
How can BT think the India call centre is saving them money I will never know...  especially as BT have the highest bills, **bleep** cheek of them!!!
------Marc------
Message 6 of 43
this is it now
This Test comprises of Best Effort Test: -provides background information.
Download  Speed
331 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 331 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :8096 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 6500 Kbps
as can be clearly seen its not even in their acceptable speed limit !!
can i with hold my payments to them as they are not fulfilling their end?
Recognised Expert
Message 7 of 43
Your IP profile and sync speeds are in line with each other and are good, its the throughput that is awful, I would email the moderators for assistance giving account and phone number and link back to this thread. forum.moderation.team@bt.com
Community Manager - Retired
Message 8 of 43
Hi geebuss,
Follow Geoff93's advice and we'll take a closer look at this fault for you.
Thanks,
Stephanie
Message 9 of 43
done
Message 10 of 43
i'm having the exact same problem as geebus. it all started very recently within the past couple of days
the bt test tells me to run test 3, but that never fully completes it usually times out with an error or says unable to run on this line.
i don't have a homehub which the help line is having one sent out to me, but imo my router is not the problem. As the help line says there is no fault on my line
below is the info off my current modem and bt speed test
    DownstreamUpstream
SNR Margin
10.523.0db
Line Attenuation
25.514.5db
Data Rate
7616448kbps
Max Rate
96961164kbps
POWER
19.512.5dbm
Results Image not loaded
This Test comprises of two tests
1. Best Effort Test: -provides background information.
Download  Speed
373 Kbps
0 Kbps7150 Kbps
 Download speedachieved during the test was - 373 Kbps
 Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
2. Assured Rate Test: -provides background information.
Download Speed
771 Kbps
0 Kbps600 Kbps
 Download speedachieved during the test was - 771 Kbps
 For your connection, the acceptable range of speeds is 576-600 Kbps.
 Assured Rate IP profile on your line is - 600 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit FAQ section if you are unable To understand the test results.
******EDIT**************
one thing i have noticed if i open a cmd promt and run a ping on google.co.uk im getting 2000 which is crazy
or ping -t jolt.co.uk it used ot be around 20-30 its now around 60 but hten if i open any web page it peaks to over 3000
something really isn't right
Tags (2)
