geebuss
Message 41 of 43
Re: speed is terrible!!!
man i just love getting home from work so that i can use my fantastic bband connection ->this is sarcasim because as you well know this is grab britain where BT roll out their fast connections slow so as to cash in as much as they can before actually being forced into change
here my connection tonight
FAQ
Results Image not loaded
This Test comprises of Best Effort Test: -provides background information.
Download  Speed
544 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 544 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :8096 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 7000 Kbps
great  britain my ass more like a 3rd world connection
isnt there some sort of way to complain to a higher authority???? OFCOM?
geebuss
Message 42 of 43
no change still rubbish no help on the horizon same old **bleep** from bt india about waiting for information from engineering department .bs
it really cant be that hard to up the capacity on a vp is it??????????
geebuss
Message 43 of 43
just bumping this to outline how inefficient BT are at fixing hot vp
delay after dalay excuse after excuse
