DannyA
Message 1 of 14
speed problems / connection drops
http://www.speedtest.net/result/1879553530.png
Normally I'm at about 6mb, Also at random times in the day the Broadband light on my router flashes orange and i lose connection for about 30 seconds before it comes back on, Not really sure what to do, Any advice would be appreciated.
13 REPLIES 13
Message 2 of 14
Re: speed problems / connection drops
welcome to the community forum where members help members
in order for the forum members to help please can you post the   adsl stats  from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester (MAC users may have problems) bt speedtester  and post the results .
are you connected directly to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
DannyA
Message 3 of 14
Bt speed tester said 0.45
Line state
Connected
Connection time0 days, 0:12:24
Downstream6,752 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)6.2 dB / 21.0 dB
Line attenuation (Down/Up)32.0 dB / 16.5 dB
Output power (Down/Up)
19.8 dBm / 12.0 dBm
Message 4 of 14
hi can you please give the full hub stats as well as the bt speedtest also are you connecting using the test socket
Message 5 of 14
can you go back to stats page and 'show detail' at bottom and post the errors.  can you also run btspeedtester and post the results please - not beta version
DannyA
Message 6 of 14
Download speedachieved during the test was - 61 Kbps For your connection, the acceptable range of speeds is 600 Kbps-7.15 Mbps. Additional Information: Your DSL Connection Rate :6.75 Mbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 5.5 Mbps
Line stateConnected
Connection time0 days, 9:48:38
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)10.1 dB / 21.0 dB
Output power (Down/Up)19.8 dBm / 12.0 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)1762948 / 0
CRC Errors (Down/Up)5 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)3
Message 7 of 14
your btspeedtester resultd show very low download speed but btspeedtestre is having severe problems just now - see post on this page by DS
Message 8 of 14
imj the speed test .net site result posted by the op also seems low may be worth the poster trying the bt test several times to see any speedtester faults
DannyA
Message 9 of 14
Still haven't solved the problem, No idea what to do.
Message 10 of 14
can you try btspeedtester again and if it works post the results please
are you connected to the test or master socket?
