Message 11 of 15
Re: speed test
your router may have been connected all week but I think if you checked the connection time you will find there has been a few resets in your week
paolo9846732
Message 12 of 15
Re: speed test
IMJOLLY
You should maybe amend your stock reply (used in every thread regarding speed issues) about using speedtester.  It is plagued with problems for MAC OSX.
It would be far more useful if you mentioned this...
Message 13 of 15
Re: speed test
thanks for that - not heard that before but I suppose there are a lot less MAC users than windows.  worth changing though
sahaya
Message 14 of 15
Re: speed test
i tested my internet connection at two different speed test site
Ip-Details.com
downloads: 1.09Mbps
uploads: 0.8Mbps
Speedtest.net
downloads: 1.98Mbps
uploads: 0.5Mbps
why is this difference between the sites though the connection is same? is my speed good?
Message 15 of 15
Re: speed test
this is a solved post.
you will get more help if you start your own subject and then post some stats from your router and also run btspeedtester and post the results
