Message 1 of 7
superfast fibre.
just upgraded to fibre and now the wifi keeps dropping out, automaticaly connect is selected, appreciate suggestions.
6 REPLIES 6
Message 2 of 7
Re: superfast fibre.
Turn off smart setup.
Turn off automatic channel selection.
Split wireless networks.
Message 3 of 7
Thank you pippincp for your advice but I wouldn't know where to find the instructions that you advise. I'm old and no IT wizz kid so I'll keep searching, thanks again JDL
Message 5 of 7
I'm getting on a bit as well,but if you follow the instructions in the links and get the hang of it,it'll get a lot easier and you'll find it useful in the future. Best of luck.
Message 6 of 7
Hi liquorice, thanks for your help, I haven't had time read all through as there is so much information but wanted to thank you for valuable help.
Message 7 of 7
Hi  B13blues, Thanks  for your help, I  now have wi-fi,  all this modern tech. can  be hard to absorb when we've been used to shoveling coal in to make the lorry go.
Thank again,
JDL
Tags (1)
