Message 11 of 12
Re: switching of my bt homehub4
deleted by poster.
Expert
Message 12 of 12
@robyn6cp wrote:
Good point mate but my fridge/freezer, cooker, washing machine, microwave etc are not plugged into a socket, they are wired to a fused switch. So any fault blows the individual fuse, so no problem
but its  different with a item plugged into a wall socket even thou it may blow the fuse in the plug but because of the heat generated could cause a fire in the component or plug.
The fuse in the plug should be suitably sized to the load drawn by the unit. I'd be surprised if it was anything more than a 3A fuse.
Fire risk is minimal, and is actually greater for fridges etc.
Ian
http://www.siteguru.co.uk/be/ADSL2PlusForDummies.pdf - Having ADSL issues? Then read this PDF
Please don't click the star beside my name - too many stars makes you look like a swot!
