kylrod
Message 1 of 8
tech help desk closed
Hi guys, have seen a few posts on here about people saying the help desk is closed, I had exactly the same problem a few months ago when I had experience issues. I got round it by when it asked u " if this is the number u want to talk about press 1 if not press 2". So press 2 and enter your number manually if will then connect to the queue. If that doesn't work enter any other number it will put u through then jst give them your proper number when they answer. This is the only way I can get through. I felt like a total idiot when I asked on here b4 everyone said I was dialing the wrong number. Hope this helps
7 REPLIES 7
minusdot
Recognised Expert
Message 2 of 8
Re: tech help desk closed
Maybe "difficult" customers get the talk to the hand treatment! 😉
Paigntonian
Message 3 of 8
I dont class 'difficult' as demanding the service you are paying alot of money for.
------Marc------
Paigntonian
Message 4 of 8
KYLROD thanks for that mate, the next time that happens to me, I'll give it a try and see what happens, cheers mate.
------Marc------
kylrod
Message 5 of 8
No probs let me know if it works for you
Paigntonian
Message 6 of 8
Out of curiosity I just rang the number and got through normally.
Whether it was closed, or just technical issues (surprise surprise) it says alot about a specialist telecoms company if they cant even answer their own telephones! lol
------Marc------
minusdot
Recognised Expert
Message 7 of 8
Well done for posting the work around kylrod. Are you a Vision customer? I note that if you look at their contact me page it shows the usual number but different hours:
From a landline dial:
0800 111 4567
From a mobile dial:
0330 123 4567*
Opening hours
7am to midnight, 7 days a week
So if you were routed automatically based on the number you are phoning on then you could be put through to a closed department.
kylrod
Message 8 of 8
no iam jst a broadband customer . i can only get through by using the work around, never by the proper route must be a fault in the IVR some where
