Message 1 of 7
third party router
should i enable bitswap? Enabling Bitswap could cause issues with the DLM?
6 REPLIES 6
Message 2 of 7
Re: third party router
It doesn’t on my Draytek, but it’s enabled by the exchange equipment.  Not me.
Message 3 of 7
what do you mean
Message 4 of 7
The DSLAM decides if bitswap is implemented or not, not you. All the setting does is enable it to be implemented.
Message 5 of 7
Sorry if I wasn’t clear.  I was trying to avoid getting too technical.
Draytek is a brand of router.  I use a Draytek 2762.
As Liquorice says, whether bitswap is used or not is determined by the equipment managing the line at the exchange.
Message 6 of 7
@WSH  The DSLAM is at the cabinet not the exchange.
Message 7 of 7
@pippincp. Yes, quite right.  I thought somebody would pull me up for that.
As I said, I’m trying to keep it non-technical for the OP.  Does the OP even know what a cabinet is, let alone a Digital Subscriber Line Access Multiplexer?  Not everyone is as knowledgeable as us and there’s something to be said for not blinding people with science.
