Hi all could you tell me if it is possible to set a time limit that a device can connect to WIFI please.
what i would like to do it cut the wifi usage to the xbox a a set time of the evening is this possible?
thanks in advance.
You should be able to do that using the parental controls. If you have a SH2 then you access the controls using the MYBT app
