cw182
Message 1 of 9
topcashback not showing:( help
Placed an order on Thursday with By expecting£156.50 back, followed the link, did everything I would do normally. Not showing any cashback. Only went with bt because of this.
Anyone else had this? Can you cancel as writhing 14 days.
8 REPLIES 8
cw182
Message 2 of 9
Re: topcashback not showing:( help
Thinking of cancellation. Anyone know if I can do this?
Webby
Message 3 of 9
Have you raised a claim with TCB?
cw182
Message 4 of 9
Yes but no reply yet. Worried as without the tcb is very expensive:(
Webby
Message 5 of 9
You should know that tcb is never guaranteed.
barbar7619
Message 6 of 9
Not the point though is it Webby
Webby
Message 7 of 9
It's very much the point
cw182
Message 8 of 9
tcb isnt guaranteed, however i have used it for sereval years and used it for BT before and never had an issue. Not sure why it hasnt work this time, havent done anything different. any change a mod can help? if not think i will have to cancel 😞
Webby
Message 9 of 9
You will need to chase this up with top cashback.
Only if TCB say they cannot provide the cashback due to a BT error will BT look into it for you.
Sometimes cashback doesn't track. You raise a missing cashback claim on TCB with your order details and they sort it out for you.
