Message 1 of 23
trying to connect Epaon XP-2100 to BT Homehub6dx
I have just upgraded to the Homehub6dx and it won't talk to my Epson printer.
I have followed all of the Epson instructions but no luck.
Any suggestions?
22 REPLIES 22
Message 2 of 23
Re: trying to connect Epaon XP-2100 to BT Homehub6dx
have you turned of smart setup
Turn Off smart setup
have you split the networks
Split the networks
Message 3 of 23
Hi, no I haven't but the link takes me to Homehub 4 or 5. Is it the same process for Homehub6?
Message 4 of 23
The link takes you to the hub6 (aka smart hub) as well
Message 5 of 23
the smart setup link has various versions of the hub but same principle applies to all
splitting the networks is the same or very similar   if you had a SH2 then you cannot split the networks
Message 6 of 23
I have turned off smart set up but couldn't split the networks as my hub is not a 4 or 5 but seems to be a 2 and the option to unsync the 2.4 and 5ghz was not available...
Message 7 of 23
Still unable to connect the printer...
Message 8 of 23
Factory reset the printer and set up from scratch.
Message 9 of 23
A friend has the same printer and I changed their hub to a SH2 on Tuesday, just pressed the WPS button on the hub, pressed the WiFi button on the printer for about 10 seconds until the 2 icons started flashing and it connected straight away
Message 10 of 23
I'm glad it worked for you, but I re-installed the software via the CD and the Hub light flashed and the printer flashed and then the printer decided that it couldn't connect...
Stuck now...
