socnsum1
Message 1 of 12
unable to receive incoming calls
Hi.
I am unable to receive incoming calls on my BT landline. I can ring out on the line and my internet connection is working.
I have tried all normal fault finding steps to try and narrow down the problem.
I have unplugged all other devices and tried just plugging in the phone. I have also tried plugging in an alternative phone.
I still get a dial tone, but everytime someone tries to ring me it goes straight to answerphone and my phone doesn't ring.
As I say I have tried two different phones and also checked that the ringer is on.
I took off the front part of my socket and plugged both phones into the test socket. Again I get a dial tone, but again I am unable to receive calls on either phone.
I am trying to work out if this is a fault at my end or at BT's end. They have done a line test for me and say everything is fine.
Does anyone have any ideas of suggestions?
I just want to know if it is a fault at my end or at BT's end as I know that there is a big charge if its a fault at my end.
Thanks in advance for any help or suggestions.
11 REPLIES 11
Distinguished Guru
Message 2 of 12
Re: unable to receive incoming calls
Have you tried calling your mobile phone to check what number is displayed? You may have a crossed line.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
socnsum1
Message 3 of 12
Hi Dave. Thanks for the suggestion. As I am ex directory no number shows up when I call my mobile from my landline. It just states unknown number. When I try calling my landline it goes straight to BT answerphone. Any thoughts?
jojojigs
Newbie
Message 4 of 12
Are you near Brands Hatch by any chance....I have exactly the same problem
socnsum1
Message 5 of 12
nope, I am in the L32 Liverpool area
Message 6 of 12
If you call your mobile and prefix the number with 1470, then your number will be displayed.
Distinguished Guru
Distinguished Guru
Message 7 of 12
KB's right. Caller ID must have been disabled on your landline - being ex-directory does not by itself prevent your number being given.
socnsum1
Message 8 of 12
Thanks. I tried that and it just went right to my mobile answerphone. My mobile didn't ring or register the call from my landline. Weird one I know. Thanks for all of the suggestions btw.
Message 9 of 12
I would try again, its probably just a mobile signal problem.
socnsum1
Message 10 of 12
I have managed to call my mobile using the landline and my mobile DOES display my landline number. Does that rule out a crossed line then? Sorry to be a pain. I really appreciate all of the suggestions that people have made. Based on what I have said do people think its a problem at my end or a BT fault?
