ooo000ooo
Message 1 of 3
unlocking the 620
Now i've got a touch 2, anyone know which number i ring to get the 620 unlocked so my OH can stick her sim in it?
2 REPLIES 2
OLD_MAN
Message 2 of 3
Re: unlocking the 620
I contacted 'Tech Support' on 0800 328 1919 and they wanted the Account ref from your last bill and the IMEA number from the phone.  Check that the original box and number inside the phone under the battery are the same before you ring them.  It took about 30 seconds to give me the 6 digit number to key in.  I was asked what SIM I intended to use first (did not know that made any difference!) but I said Orange PAYG. I inserted the SIM, keyed in the 6 digits and hey presto - it is unlocked.  I kept the number in case it was required when doing a factory reset but it was not required.
I also understand that the Unlock code is specific for your IMEA reference.
OLD MAN ( 3 x 20 + 10, Hero + 620 user )
ooo000ooo
Message 3 of 3
cheers old man, s620 now unlocked
