Soultrap102
Message 1 of 5
upgrade to bt youview.
i would like the new youview box but i have a complicated bill.
i had issuses with my home hub i had it replaced and a got a specail offer on my broadband and bt vision.
now im wondering if the new youview box will rasie my bill.
moderator help is most welcome.
4 REPLIES 4
minusdot
Recognised Expert
Message 2 of 5
Re: upgrade to bt youview.
It sounds like you're still within the minimum term of your broadband and vision contract. A YouView box from BT will cost you £299.
Soultrap102
Message 3 of 5
thats crazy i have a really old silver box. that i have to keep restarting every 5mins
Smiffy71
Message 4 of 5
I would imagine if it's the old silver BT box that you are out of your initial contract and can therefore upgrade to the new Youview box. I would suggest that you give BT a ring and talk to someone about a prospective order and they will help you. I rang up on Saturday and received my box this morning, some people are having issues with delivery times though.
minusdot
Recognised Expert
Message 5 of 5
Well good luck. But if you're having to reboot your silver box so often then it's probably faulty and BT will replace it if you're in contract.
