dirtybri
Message 1 of 8
upgraded to aa faster broadband version it worked ok then stopped
Can anyone help me? I have always been a bt broadband customer, on Thursday i had my connection up graded to a faster bt broadband, all worked ok then 3 hours later my HH5 shows a steady orange light and i have no internet
I have done all the usual checks (switch off/change adsl filter etc) and still nothing!
Any ideas would be most welcome before the wife strangles me lol
7 REPLIES 7
ray_dorset
Distinguished Guru
Message 2 of 8
Re: upgraded to aa faster broadband version it worked ok then stopped
Can you post your line stats from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254
Lines 1-13 will be enough
If not, I'll try again 🙂
dirtybri
Message 3 of 8
I would if i could get on the internet
DavidM
Moderator
Moderator
Message 4 of 8
Welcome and thanks for posting dirtybri.
I think we need to take a closer look at this for you. Can you drop me an email with your details? You'll get the 'contact us' link in my profile.
Cheers
David
ray_dorset
Distinguished Guru
Message 5 of 8
I suggest you try a factory reset of the hub
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-home-hub-to-its-factory-...
dirtybri
Message 6 of 8
Tried factory reset about 4 times and none have worked
ray_dorset
Distinguished Guru
Message 7 of 8
Please post the line stats.
Do you have wireless turned OFF on the HH5? Try turning it ON.
DavidM
Moderator
Moderator
Message 8 of 8
Looks like the enigneer visi got this sorted for you dirtybri. If you have any other problems let us know and we'll be happy to help.
Cheers
David
