portugal
Message 1 of 4
using English BT answer phone in Portugal
Took by BT anwser phone but even though I plugged in Portuguese power cable and telephone which although me to set it up when I called my number it would not ring or work help please
3 REPLIES 3
Message 2 of 4
Re: using English BT answer phone in Portugal
BT phones are designed to work on the UK phone network the networks are different from country to country so very unlikely to work
Message 3 of 4
Absolutely agree: a completely different system, like chalk and cheese. Un-plug, get rid of, and use something in Portugal comms network.
AQ.
"Welcome to Royston Vasey - You'll never leave."
Distinguished Guru
Message 4 of 4
Hi it will work ok providing you get the correct pin outs from the cable from the phone to the phone socket, obviously different on BT sockets.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
