Message 1 of 10
using NETGEAR ProSafe SRXN3205 router with OpenReach modem
I've just had my BT Infinity install completed this morning. I'd really like to use my existing NETGEAR ProSafe SRXN3205 router in conjunction with the OpenReach modem instead of the BT Home Hub 3.
I'm struggling to get it to work. I've reset my NETGEAR to factory defaults, then entered the username "bthomehub@btbroadband.com" in the appropriate field on the NETGEAR's configuration.
Still no joy. Anyone got this same setup and working and can offer some assistance?
9 REPLIES 9
Recognised Expert
Message 2 of 10
Re: using NETGEAR ProSafe SRXN3205 router with OpenReach modem
I wonder if this is of use regarding a Netgear but model WNR3500L....
"obviously I will have to configure the web interface to connect via PPPoE and use the HH's login credentials "
From this thread http://community.bt.com/t5/BT-Infinity/Replacing-HH2-with-another-router/m-p/236983/highlight/true#M...
Please Click On any Text in Blue as that automatically links to information.
PC (NDEGR)
Message 3 of 10
Thanks. Unless anyone can tell me otherwise, I'm fairly sure that's what I've done. I've left everything else at the default configuration but added "bthomehub@btbroadband.com" as the username in appropriate field, and left the password blank. The status page on the router just shows "not yet connected" or some such phrase.
Message 4 of 10
Try using your £@$%$%$@btinternet.com email address as your username and BT as the password.
Message 5 of 10
Why do you suggest that? If that is indeed the username and password to use, then it would mean the BT Home Hub has been delivered to me pre-configured with that same username and password. I don't think that is the case. I'm sure all Home Hubs are delivered in "factory reset" state.
Message 6 of 10
Hi, as you said it should be just bthomehub@btbroadband.com and the other field left blank, my cousin needed to know this to set my TP-Link router up i don't know what else he dne as he's the techie. But that's the info i had to get from a mod on here for him to set it up.
Regards
Guy
Message 7 of 10
Hi Galexa,
In a post a while back, someone had to put a "space" in the password section to get their router working.
It's worth a try, I would say that during the training period it's best not to turn the router and/or the modem off and on, as this can indicate a fault to the gear in the exchange and this reduces your profile i.e. the max speed you will get!
Michael
Expert
Message 8 of 10
Hi there,
I'm using a Netgear WNR3500L and when I set up the connection, what I did was use the following:
username: bthomehub@btbroadband.com
password: [anything you like as long as it isn't left blank - I personally used "bt"]
See below for a screenie. 🙂 🙂
I hope this info helps. 😄
*** Edited to evict that pesky typo gremlin again! 😛 ***
Recognised Expert
Message 9 of 10
Hi Galexa
Fingers crossed Rottie's info will help you get it going.... Smiley Happy
If it does and you're happy with the Netgear SRXN3205 as a substitute for the HH3, would you consider posting in the thread shown below as a known working replacement?
http://community.bt.com/t5/BT-Infinity/List-of-Routers-to-replace-Home-Hub-3/td-p/298203
PC (NDEGR)
Message 10 of 10
Putting something/anything in the password field appears to solve the problem. Thanks for the help.
