Message 11 of 28
Re: using third party router
Thanks for the tip .. might have to think about it tho as some reviews on Amazon call in to question the stability of its 5Ghz wifi as well as an apparent tendancy to randomly assign DCHP IP addresses .. any other options much appreciated
Message 12 of 28
@philbern
I'd say that the Asus is about as stable & reliable as any modem/router you'll find on the market.
I use both the 2.4 & 5GHz frequencies without any perceived isses.
Also all my home devices are set as predefined ip addresses with only visitors - family members - picking up ip addresses from DHCP so I've not seen that issue either.
Message 13 of 28
Thanks.. If I go ahead with the Asus.. Can I find an idiot's set up guide somewhere to ensure I get things done properly re Infinity, BTTV and VPN.. 😊
Message 14 of 28
I am sure @TimCurtis  will be able to help, if you cannot find the information within this forum.
Try this post https://community.bt.com/t5/Home-setup-Wi-Fi-network/ASUS-DSL-AC68U-Settings/m-p/1873250#M154356
Message 15 of 28
Of course I'll do my best to help.
Just a point about VPN. As a server you've only 2 options which are PPTP - now not supported by Apple 😞 - and OpenVPN. As a client again OpenVPN and PPTP & L2TP to any compatible server I think.
Message 16 of 28
I have a third party router wired to my bt home hub, not a modem router, it's an asus rt-ac87u,.to set it up :-
set up bt hub:-
type into browser 192.168.1.254 to get to the hub homepage.
Advanced settings>ipv4 set up > change ip address to 192.168.2.1.save settings
Change ip start address to 192.168.2.64, Change ip end address to 192.168.2.253. save settings
Turn off wireless. save settings
now configure your router depending on make and model.
connect 3rd party router
in the browser go to the routers web page (example:-192.168.0.1)
set the 3rd party routers ip address to 192.168.1.40. save setting.
disable dhcp server. save setting.
connect the two routers via 1) the wan port on your 3rd party router > ethernet port 1 on bt hub. switch them both on wait for initialisation .it should work .
Message 17 of 28
Fine if you are happy double natting.
Message 18 of 28
I am having zero problems with it .
Message 19 of 28
Re: using seperate router help please
I have bought and installed a DSL-AC68U and the internet is working well. The BT TV has internet connection via IPTV. I can see channel information but unfortunately these do not work when selected - blank screen. The YouView box then comes up with an error message. Have you got BT TV and successfully got this to work?
Message 20 of 28
Yes, we experienced the same issue, the blank screen will not go away, did anyone have a solution, please?
Many thanks
Lee
