hi folks
just signed up for IPTV, and its buffereing, so I checked my BB speeds
on
Speedtest.net = 4m
boardbandspeedchecker = 5m
speedtest/btwholesale = 16m
all of these tests were carried at one after the other
then i tested speedtest/btwholesale twice with no gap between tests
first test it said 4m
second test is said 16m
I can see if the tests are 5 minutes about there could be different speeds but how can it be different if its seconds different in testing
The BT Wholesale test is the only reliable one, as its not affected by general Internet congestion.
Beware flash based sites etc.
Try this one, it uses HTML5 in the browser.
Not all browsers are happy with HTML5 yet
yes wired connection
still does not explain why 2 tests with BTW seconds apart show around 10m different in speed
test 1 6m
test 2 16m
thanks
just didn't think it could vary over seconds
