Spewy
Message 1 of 6
viewing on multiple screens
Hi all,
I recently moved from Sly to BT. My main Sly box was located in my main sitting room but i could view the same screen in another room that was connected via coax cable. Since BT was installed i have lost that capability.
Is there a solution to this?
Thanks in advance
5 REPLIES 5
benwiddowson
Expert
Message 2 of 6
Re: viewing on multiple screens
There are a few solutions. One would be to run a scary out of the back of the youview box through an rf modulator and then on to your other TVs via a coax cable (just like your sky box does). The second would be scart out the back of the BT box and use a video sender. The solution I use is to use a home splitter and send the bt signal to my tv's via hdmi over cat5e.
If you pick a solution we will help you buy the right bits and install your setup. Controlling the system is a different kettle of fish.
benwiddowson
Expert
Message 3 of 6
Scary = scart (iPad issues)
benwiddowson
Expert
Message 4 of 6
Oh and home = hdmi.
Spewy
Message 5 of 6
Thanks for the input
What is the cost for the options you suggested?
benwiddowson
Expert
Message 6 of 6
RF modulators are less than £25 on Amazon or eBay. I have hdmi over cat 6 which cost about £60 but obviously you have the issue of having to run network cable. Ours was a lot easier as its a new build and I had it pre wired with network cable when it was being built. Video senders are about £30+ but if you want 5ghz ones (I'd suggest these if you do choose this option,you could probably double the price easily).
