Message 1 of 2
water leak
can  water leaks ruin BT  networking cables underground?
thames water says they will fix it but its been 3 or 4 months now. and the bt man hole cover is filled with water, all down the street too.
1 REPLY 1
Message 2 of 2
Re: water leak
It can do if the cable joints haven't been sealed properly, but on the whole it isn't a problem its quite normal for ducts and joint boxes to be filled with water in wet weather.
