mousegibson
Message 2 of 4
webpage help
Hi
Wondered if you could help.
Recently several pages have refused to load completely, others load after several minutes, but only load the hyperlinks on the website.
the sites in question are
WHATCULTURE.COM
Skysports.com
and RBS.co.uk
bleacherreport.com
Its driving me crazy as some pages work perfectly but those just don't
any help would be great
3 REPLIES 3
mousegibson
Message 1 of 4
Webpages not loading
Hi
WHATCULTURE.COM
http://bleacherreport.com/uk
Skysports.com
and RBS.co.uk
conrad
Recognised Expert
Message 3 of 4
Re: webpage help
I use the latest Firefox and just copying and pasting the sites I had no problems at all loading the pages.
Have you cleared your history and cache.
gg30340
Message 4 of 4
Re: Webpages not loading
If you are using Internet Explorer try using it in Compatability View. Try and open the site you want to go to then click on Tools at the menu bar then scroll down to and tick Compatability View.  Press F5 to see if it loads OK.
