Message 1 of 4
what to do with old router
hi i have a old BT router 2 and a very old orange router, im 99.9% sure they will never be used again. What should i do with it. I have local electronic recycling banks for small items, is that the best and safest thing to do?
3 REPLIES 3
Message 2 of 4
Re: what to do with old router
More than likely yes 🙂 Or you could keep it just in case the one you're using goes faulty. You could then use it until you get a replacement.
Message 3 of 4
old routers
hey there, posted in a quieter part of the forum, hope this is ok to post here. I have an old BT HH 2 and a very old Orange router which will never be used again. Is it ok to put in my local electronic recycling is it under my name if someone was to use it in future? What do people normally do with them?
Message 4 of 4
Re: old routers
you can anything you like with them - keep 1 just in case existing router crashes and recycle the other
