Showing results forΒ
Search instead forΒ
Did you mean:Β
cinek
Message 1 of 7
when will i get my bill?
had everything installed on the 22nd Jan. Still haven't received my bill. Have no idea what my account number is. Can't do anything in my bt without the account number 😞
6 REPLIES 6
Distinguished Guru
Message 2 of 7
Re: when will I get my bill?
You should have received some notification of your new line install, the account number would be shown on there.
You may not actually receive a paper copy of the bill, it may just be on line accessed via MYBT.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
cinek
Message 3 of 7
thanks, when I go to mybt it says there are no accounts associated with it, so I need an account number to use mybt 😞
Message 4 of 7
the email would have also shown your phone number
cinek
Message 5 of 7
btw there's no account number in any of the emails I received
Message 6 of 7
have you had any letters from BT
cinek
Message 7 of 7
I just tried logging in with the email address rather than the username and it's all there. Not sure why it didn't work with the username
