Newbie
Message 1 of 3
which apps do i use on my andriod phone & tablet with my bt email.
Since the upgrade from bt yahoo I now login to my emails using the bt web site on my laptop. a bit of a faff but can see everything. However which app is best for my andriod phone & tablet?  I currently use the samsun mail app which doesn't show all my folders and isn't quite in sync if I answer on my tablet or phone against the web site.  Wondered what other users could suggest to make my life easier.
Ta
2 REPLIES 2
Message 2 of 3
Re: which apps do i use on my andriod phone & tablet with my bt email.
I use the Aqua mail app from the Play Store on an Android phone and tablet and I have found it to be very good.
The setting you need are here
http://bt.custhelp.com/app/answers/detail/a_id/44917/kw/bt%20mail/c/346,6588,6591
If you still want to use the Samsung app you need to set it up as an IMAP account. I think the default set up is a POP3 account which is why it won't sync with each of your devices.
Newbie
Message 3 of 3
excellent, thanks for that.
