Hibiscusgirl
Message 1 of 3
which wi fi extender
hello, I need some advice on whether to get the BT11acDual Band WIFI extender or the Mini Home Hotspot 600 Kit. Bt have agreed to upgrade my Home Hub 2 to a 3 but i still want to improve my wi fi. our home is a long Victorian school converted, with 2 9inch brick walls right in the middle of it, virtually separating it in two halves! any advice will be greatly appreciated1
2 REPLIES 2
licquorice
Message 2 of 3
Re: which wi fi extender
Personally I would go for the Mini Home Hotspot 500 (not sure there is a 600) if your mains wiring is OK. WiFi extenders are reliant on receiving a good signal from the hub in the first place limiting where they can be placed and how well they operate. With a powerline type device, the hotspots can be positioned anywhere as they are not reliant on receiving a wifi signal from the hub.
Hibiscusgirl
Message 3 of 3
Than you for that. It has helped me to decide what to buy.
